VOX 252-CENTER
Characteristics and sound properties
The VOX 252-CENTER is the corresponding centre speaker to match the VOX 252. This is a horizontal speaker equipped with identical drivers. The TIW 250 8 Ohm bass speaker and a BR 14.70 tube are positioned to left and right of the mid- to high-range unit, which is arranged vertically, behind a fabric-covered frame. If required, the drivers in the speaker can be fitted with compensating magnets to shield them magnetically. The VOX 252-CENTER has the same excellent sound properties as the VOX 252. The reproduction of the unbelievably sonorous low-range bass and, at the same time, extremely clear-cut mid- and high-range reproduction, is mastered effortlessly by the VOX 252-CENTER. This centre speaker is the ideal choice if you want to build up a multi-channel system around the VOX 252, that will appeal to both seasoned music lovers and aficionados of the cinema.
No longer available.
Component parts list for 1 box
Tweeter:
KE 25 SC 8 Ohm
1 piece
Midrange driver:
AL 130 8 Ohm
2 pieces
Woofer:
TIW 250 8 Ohm
1 piece
Crossover:
Bass reflex tube:
BR 14.70 (full length)
1 piece
Terminal:
1 piece
Damping material
4 bags
Special wood screws:
5 x 30 mm
4 pieces
Wood screws:
3.5 x 19 mm
16 pieces
Countersunk screws:
3.5 x 25 mm
4 pieces
Material for speaker covers
width 50 cm
1 m
Cable:
2 x 2.5 mm2
2 m
2 x 1.5 mm2
2 m
Technical Data
Rated power
200 W
Maximum power
350 W
Nominal impedance Z
4 Ohm
Übertragungsbereich (-10 dB)
28 - 25000 Hz
Mittlerer Schalldruckpegel
84 dB
Trennfrequenz
200 / 3000 Hz
Gehäuseprinzip
Net volume
70 l + 4 l
Außenmaß Höhe
480 mm
Außenmaß Breite
870 mm
Außenmaß Tiefe
270 mm
Accessories
Compensating magnet
1 piece
2 pieces
