VIB 2000 GF
      Art. No.
      5906
        Building instruction
Exploded drawing
Assembly
The circular cut-out (73 mm ø) in the baffle is for the BR 15.34 tube. The 78 mm cut-out in the rear panel is for mounting the ST 77 terminals. The crossover unit is mounted on the panel behind the bass cut-out.
Inner damping
The damping is a simple matter: as shown in the diagram, the four free square openings of the stiffening construction take one mat each, so that the upper part of the speaker cabinet is loosely filled. The lower part is left completely empty.
Zuschnittliste für 1 Box
Parts
              Size (mm)
            Quantity
      Material: 19 mm chipboard or MDF
      Front / rear panel
              210 x 862
            2
      Side panels
              900 x 296
            2
      Top / bottom panel
              210 x 296
            2
      Brace
              210 x 100
            2
      Brace
              258 x 100
            2
      Base panel
              258 x 210
            1
