Do you have any questions?
FIESTA 20
Building instruction
Exploded drawing
Aufbau
The FIESTA 20 is a simple-to-make and straightforward upright cabinetwith no complicated "extras".
As can be seen from the drawing, you will have to glue a reinforcing cross-piece between the two cut-outs for the bass speakers made up of a cross stiffener and a longitudinal stiffener.
The crossover unit of the FIESTA 20 is mounted on the rear panel behind the cut-out for the upper bass speaker.
Inner damping
The damping of the speaker uses eight mats of damping material pushed through the bass speaker cut-outs into the cabinet. The entire inside space of the speaker cabinet should be filled loosely with damping material.
Cabinet parts list for 1 box
Parts
Size (mm)
Quantity
Material: 19 mm chipboard or MDF
Top and bottom panel
300 x 262
2
Side panel
1000 x 300
2
Front and rear panel
962 x 262
2
Brace
70 x 262
2
Base
262 x 262
1
Crossover
Contact us
