Do you have any questions?
SUB PA 240
Art. No. 5874
Building instruction
Exploded drawing
Building instructions
If the speakers are likely to be transported frequently and in order to reduce resonance, it is advisable to make the cabinets out of multilayer board with a thickness of 22 mm. This will make the cabinets very resilient, even to rough jolts. The ideal surface finish is a scratch-resistant texture paint or you can glue carpeting to them. The drawing shows terminal block ST 77. However, a mounting plate with Speakon connectors is far more professional. As one would expect, carrying handles in the side walls or castors are an essential aid if the cabinets are frequently transported. The acoustic baffle is moved 50 mm back, in order to protect the driver. Additionally, a grille can also be fitted to the subwoofer (the grille and other accessories mentioned are all available in musician‘s shops).
Parts list for one cabinet
Parts
Size (mm)
Quantity
Material: 22 mm plywood or MDF
Front
556 x 954 mm
1
Lid
530 x 600
1
Rear wall
556 x 1056
1
Base
530 x 600
1
Sides
500 x 1056
2
BR channel
556 x 222
1
Verstrebung BR Kanal
80 x 222
1
Verstrebung Diagonal
40 x 450
2
Verstrebung Fron/Rückseite
40 x 556
4
Verstrebung Seiten
40 x 436
4
Verstrebung Mitte
60 x 436
2
Verstrebung Deckel
60 x 326
2
Contact us
