Do you have any questions?
ALTO GENESIS SUB
Building instruction
Exploded drawing
Assembly
In order to simplify the cabinet construction as far as possible, we have done without the chamfers shown in the photo. If you prefer to include the all-round front chamfer, you will need the following information:
Sub: 14 mm; 45°
First of all, the individual boards are cut to size (refer to cutting list), stuck together (butt jointed) as shown in the drawing and firmly clamped for the duration of the drying time using sash cramps or parcel tape. Before the final side panel of the subwoofer cabinet is stuck in place, fit the inner baffle.
In order to make it possible to fit components inside the cabinet, the base has to be removable and screwed in place. The base, to which the terminals are later attached, is positioned on a frame made of laths along the full length of the inside panels of the cabinet. Once the cabinet has been completely built, the cut-outs are made for the bass tube and terminals using a jig-saw. The last job is the surface treatment, i.e. painting, veneering or adhesive film.
The two subwoofer units are connected to the output on the amplifier via the terminals marked "IN". The satellite speakers are connected up to the corresponding subwoofer unit via the terminals marked "Sat".
Installation of the subwoofers:
- The two bass speakers can be positioned side by side to form a normal mono subwoofer. There are advantages, however, in positioning each subwoofer separately according to its stereo channel (right/left). The best position for each speaker and the distance between them is found by trial and error.
- The speakers can be positioned standing upright or lying down. The distance from the bass port to the nearest diffracting or reflecting surface (wall of the room, item of furniture) must be at least 10 cm.
- Erecting speakers near the walls of the room or in a corner can considerably increase the bass effect.
- Due to the low cut-off frequency (110 Hz), bass speakers can easily be positioned behind items of furniture or curtains without losing soundquality.
Inner damping
One mat is put into the closed chamber of each subwoofer.
Cabinet parts list for 1box
Parts
Size (mm)
Quantity
Material: 16 mm chipboard or MDF
Top panel
200 x 200
1
Bottom panel
168 x 168
1
Side panel
474 x 168
2
Side panel
474 x 200
2
Inner baffle and frame
168 x 168
2
Crossover
Press
Extract from Audio
"A masterly performance - the bass system produced such deep, deep bass attacks with such amazing clarity from its bandpass cabinets that it ended up with no less than 50 points."
Value for money: very good
Extract from HiFi Test
"The listening test proved the value of the impressive deep bass qualities ...." "While the satellite speakers provided the necessary crystal-clear mid- to high-range fill-in ...." "The testers at HiFi Test only have one recommendation to make Buy!"
Verdict: very good
Contact us
