Do you have any questions?
SUB W-20.39
Building instruction
Exploded drawing
Assembly
Simply glue the boards together (butt-jointed). The chamfers on the bafflecan be applied with a power jig or circular saw set to 45° or applied later using an orbital sander.
Next, cut out the openings for the drivers and the bass reflex tube. If an amplifier module is to be used, the cut-out required for fitting it is cut into the rear wall. If no amplifier unit is to be used, fit the ST 77 connection terminals in the rear wall.
Inner damping
Distribute the 4 mats of damping material uniformly throughout the cabinet.
Cabinet parts list for 1 box
Parts
Size (mm)
Quantity
Material: 19 mm chipboard or MDF
Top and bottom panel
282 x 389
2
Side panels
396 x 389
2
Rear panel
396 x 320
1
Brace
358 x 100
1
Brace
282 x 100
1
Material: 22 mm MDF or wood
Front panel
396 x 320
1
Contact us
