Do you have any questions?
CENTER 130
Building instruction
Exploded drawing
Assembly
The construction of this cabinet is remarkably simple since all the boards are straight-side and simply glued (butt-jointed) together. However, care must be taken to ensure absolute dimensional accuracy, as the front grille will not fit if the tolerances are too great. The grille's outer dimensions are 136 x 389 mm.
Inner damping
One mat of damping material is loosely pushed into the cabinet.
Cabinet parts list for 1 box
Parts
Size (mm)
Quantity
Material: 12 mm chipboard or MDF
Rear panel
136 x 389
1
Side panel
250 x 413
2
Top and bottom panel
136 x 250
2
Material: 16 mm chipboard or MDF
Brace
136 x 80
1
Front
136 x 389
1
Crossover
Press
Extract from Audio Vision
"The surprise candidate during the test series came from Visaton. The CENTER 130 produced a well-rounded sound, whose crisp mid-range was particularly worthy of note"... Without including your own work and the costs of materials, the value for money is exceptionally good."
Contact us
