CT CENTER 200
CT CENTER 200 is based on the CT MAIN 200 main loudspeakers and acts as a Centre Speaker, where the only difference is that it is designed to lie on its side. Since the speaker arrangement and crossover unit are identical in every respect, this centre system is ideal for use with THX® systems. With its linear frequency response of 80 Hz 20,000 Hz in an enclosed cabinet with a total Q-rating of 0.7, the required vertical beaming and a maximum sound pressure of 108 dB, this system leaves nothing to be desired. The loudspeakers used, W 130 SC 4 Ohm and W 200 SC 4 Ohm, are magnetically shielded and the shielding of the complete speaker unit corresponds to THX® regulations (3-Gaussian curve). This means that the entire speaker can also serve as a stand for a TV set. The speaker is a titanium dome tweeter with a neodym magnet. The CT CENTER 200 can also be used as a main loudspeaker and, because of its overall dimensions, can be placed on top of a SUB T-40 subwoofer. This speaker has extremely clear bass reproduction with a well-balanced overall sound quality, and impressive spatial separation. High volume settings, particularly important to reproduce live sound, come across powerfully, naturally and undistorted involving the listener directly in the action. The designers placed emphasis on high impedance, so that the speakers can be connected up to virtually any amplifier with no problems. We recommend using this system in conjunction with CT MAIN 200 main loudspeakers, the CT DIPOL 130 effect speaker and the SUB T-40subwoofer. The virtually perfect reproduction of the sound channels is so close to the original that the listener feels as if they are personally involved in the action. Makes films into an experience.
| Rated power | 150 W |
| Maximum power | 230 W |
| Nominal impedance Z | 8 Ohm |
| Übertragungsbereich (-10 dB) | 80 - 20000 W |
| Mittlerer Schalldruckpegel | 89 dB (1 W/1 m) |
| Trennfrequenz | 300 / 2500 Hz |
| Gehäuseprinzip | geschlossen / closed |
| Net volume | 33 l + 4 l |
| Außenmaß Höhe | 400 mm |
| Außenmaß Breite | 630 mm |
| Außenmaß Tiefe | 246 mm |
