Do you have any questions?
CT MAIN 100
For use as a small satellite, the CT MAIN 100 is equipped with a pair of W 100 S 4 Ohm and the G 25 ND 8 Ohm textile dome unit. The two woofers are connected in series, which produces a total impedance of 8 ohms. As a result, the CT MAIN 100 can be used in conjunction with receivers that have problem communicating with low-impedance speakers. The drivers are arranged symmetrically on the baffle based on the D'Appolito principle, where the oval front panel of the tweeter leaves only very little space between the woofers.
The CT MAIN 100 can be used as the main speaker in a multichannel system (e.g. CineTOP 100 combination using 2x CT MAIN 100, 1x CT CENTER 100 and 2x CT DIPOL 100, boosted with an active subwoofer), or as the satellite in a stereo system. As subwoofer, the SUB W-20.39would be a suitable choice.
Technical Data
Component parts list
Additional Content
Rated power 60 W
Maximum power 100 W
Nominal impedance Z 8 Ohm
Übertragungsbereich (-10 dB) 80 - 30000 Hz
Mittlerer Schalldruckpegel 85 dB (1 W/1 m)
Trennfrequenz 2000 Hz
Gehäuseprinzip geschlossen / closed
Net volume 8 l
Außenmaß Höhe 396 mm
Außenmaß Breite 160 mm
Außenmaß Tiefe 210 mm
Component parts list for 1 box
The kit includes all necessary components (see list below). Cabinetparts are not included.
Tweeter:
G 25 ND 8 Ohm
1 piece
Woofer:
W 100 S 4 Ohm
2 pieces
Crossover:
Crossover CT MAIN 100
Terminal:
ST 77
1 piece
Damping material:
1/2 bag
Countersunk screws:
3,5 x 25 mm
16 pieces
Cable:
2 x 1,5 mm2
1 m
Frequency- and impedance response
Contact us
