Do you have any questions?
FIESTA 30
A loudspeaker that produces similar sound characteristics in the hi-fi field as the FIESTA 20, but, due to its higher efficiency rating, can also double up as a speaker for the electronic organ at home and be used in the party room; that is the FIESTA 30.
At the lower end of the frequency scales in this all-round system, we find the tough 12" BG 30 NG 8 Ohm in a generously sized 130-litre vented cabinet. The mid- to high-range is covered by the new BG 20 8 Ohm and the DHT 9 8 Ohm tweeter horn.
The result is a high efficiency rating of 91 dB (1 W/1 m) at impedancelevels that are not amplifier-sensitive and a music load of no less than 250 W.
The robust reproduction quality required for party use or for a musician is complemented adequately by the smooth frequency response with the neutral hi-fi sound qualities required in a home listening environment.
Technical Data
Component parts list
Additional Content
Rated power 150 W
Maximum power 250 W
Nominal impedance Z 8 Ohm
Übertragungsbereich (-10 dB) 40 - 38000 Hz
Mittlerer Schalldruckpegel 91 dB (1 W/1 m)
Trennfrequenz 500 / 4000 Hz
Gehäuseprinzip Bassreflex
Net volume 130 l
Außenmaß Höhe 1319 mm
Außenmaß Breite 360 mm
Außenmaß Tiefe 360 mm
Component parts list for 1 box
Tweeter:
DHT 9 8 Ohm
1 piece
Midrange driver:
BG 20 8 Ohm
1 piece
Woofer:
BG 30 NG 8 Ohm
1 piece
Crossover:
see diagram
Bass reflex tube:
BR 14.70 (length: je 14,5 cm)
2 pieces
Terminal:
PT 57 NG
1 piece
Cover cap:
AK 14.20
1 piece
Damping material:
4 bags
Wood screws:
4 x 20 mm
30 pieces
Cable:
2 x 1,5 mm2
3 m
Frequency- and impedance response
Contact us
