Do you have any questions?
MB 156/3
The MB 156/3 extends the range of musicians' speakers available from Visaton by adding one new 3-way combination. The bass department is controlled in this arrangement by the BGS 40 - 8 Ohm, which is a carry-over from the successful MB 115/H. The mid-range is provided by the BG 17 - 8 Ohm which, thanks to its high sensitivity level, has no problem at all matching the output level of the woofer. The combination is neatly rounded off at the top range of frequencies by the HTH 8.7 - 8 Ohm horn which has also already made a good impression in other speakers.
To ensure that the high sensitivity of the BGS 40 - 8 Ohm, which on average is 95 dB (1 W/1 m), is also achieved at the low frequency range, there are two bass reflex vents in the baffle. Having the tuning frequency set at a high 55 Hz means that the thickness of the material used for the front panel is sufficient as the length of the bass reflex tubes. No tunnels or tubes are required.
A well-tuned crossover ensures that each of the three drivers only deals with the range of frequencies for which it was originally designed. In the case of the MB 156/3, this arrangement results in a highly linear frequency response, even at high output levels, which is close to hi-fi needs.
Technical Data
Additional Content
Rated power 200 W
Maximum power 300 W
Nominal impedance Z 8 Ohm
Übertragungsbereich (-10 dB) 54–20000 Hz
Mittlerer Schalldruckpegel 95 dB (1 W/1 m)
Trennfrequenz 700 / 4500 Hz
Gehäuseprinzip Bassreflex
Net volume 90 l + 4 l
Außenmaß Höhe 700 mm
Außenmaß Breite 450 mm
Außenmaß Tiefe 420 mm
Frequency- and impedance response
Component parts list for 1 box
Tweeter
HTH 8.7 - 8 Ohm
1 pc.
Mid-range
BG 17 - 8 Ohm
1 pc.
Woofer
BGS 40 - 8 Ohm
1 pc.
Crossover
ST 77
1 pc.
Damping material
Polyester wool
2 bags
Terminal
MB 156/3
1 pc.
Wood screws
3,5 x 19 mm
4 pcs.
Wood screws
4 x 20 mm
12 St.
Special wood screws
5 x 30 mm
8 pcs.
Countersunk screws
3,5 x 25 mm
4 pcs.
Cable
2 x 2,5 mm²
1,2 m
Cable
2 x 1,5 mm²
1,5 m
Contact us
