Do you have any questions?
VIB MIKRO AL
Building instruction
Exploded drawing
Assembly
The cut-out for the tweeter is made using the templates supplied with the speakers. The cabinet of the speaker has a chamfer to reduce edge reflection. This effect can be enhanced still more by flush mounting the two loudspeaker drivers in the baffle. This plus the compact dimensions of the front give the VIB MIKRO AL its excellent distribution characteristics. The crossover unit is mounted on the base of the cabinet.
Inner damping
The damping uses one mat of damping material rolled up and placed vertically into the cabinet.
Cabinet parts list for 1 box
Parts
Size (mm)
Quantity
Material: 19 mm chipboard or MDF
Front and rear panel
300 x 200
2
Side panel
300 x 212
2
Top and bottom panel
212 x 162
2
Crossover
Contact us
