Do you have any questions?
ATLAS COMPACT MK IV
This, the fourth version of the ATLAS COMPACT, now boasts the latest driver highlights that the VISATON range has to offer. Apart from the TIW 360 8 OHM and AL 170 8 OHM used in the MK III version, the latest version makes use of the TI 100 8 OHM as the mid-range loudspeaker and KE 25 SC 8 OHM as the tweeter. The crossover unit has been completely redesigned and adapted to match the new drivers.
The baffle has also been changed. The wide bevels make the cabinetlook that much slimmer and prevent edge-reflexions in the more susceptible mid- and high-ranges. The bass reflex tube has also been modified. By using a larger tube, flow noise and losses have been reduced.
The ATLAS COMPACT MK IV is a very dynamic speaker with powerful deep-black bass reproduction but without getting woolly in the bass department. Additional features are absolutely neutral voice reproduction and crystal-clear high-frequency sounds without sharp edges.
Technical Data
Component parts list
Additional Content
Rated power 200 W
Maximum power 300 W
Nominal impedance Z 8 Ohm
Übertragungsbereich (-10 dB) 25–25000 Hz
Mittlerer Schalldruckpegel 88 dB (1 W/1 m)
Trennfrequenz 350 / 1200 / 3000 Hz
Gehäuseprinzip Bassreflex
Net volume 130 l + 18 l + 0,8 l
Außenmaß Höhe 1374 mm
Außenmaß Breite 360 mm
Außenmaß Tiefe 400 mm
Component parts list for 1 box
Tweeter:
KE 25 SC - 8 Ohm
1 pc.
Midrange driver
TI 100 - 8 Ohm
1 pc.
Bass-midrange driver
AL 170 - 8 Ohm
1 pc.
Woofer
TIW 360 8 OHM
1 pc.
Crossover
"Atlas Compact MK IV"
Bass reflex tube
BR 14.70 (length: 14.5 cm each)
2 pc.
Cover cap
AK 10.13
1 pc.
Terminal
BT 95/75
1 pc.
Damping material
6 bags
Special-wood screws
5 x 30 mm
8 pcs.
Wood screws
4 x 20 mm
12 pcs.
Countersunk screws
3.5 x 25 mm
4 pcs.
Cable
2 x 2.5 mm2
2.6 m
2 x 1.5 mm2
3.4 m
Frequency- and impedance response
Contact us
