CT CENTER 100
Characteristics and sound properties
This compact centre speaker will find a suitable space in the shelving just above or below the TV set. It is fitted with two W 100 SC 4 Ohm 's connected in series, which produces a total impedance of 8 ohms. As a result, the CT CENTER 100 can be used in conjunction with receivers that have problem communicating with low-impedance speakers. Up in the high-frequency range, the G 25 ND 8 Ohm, a 25 mm textile dome unit with a Neodym magnet, performs well. The tweeter is arranged asymmetrically between the woofers in order to achieve an enhanced horizontal radiation pattern. All the drivers are, of course, magnetically shielded to prevent annoying interference effects on TV screens.
Apart from the CineTOP 100 combination consisting of 2x CT MAIN 100, 1x CT CENTER 100, 2x CT DIPOL 100 and the active subwoofer, it is also possible to combine the Centre and Dipole speakers with small or medium-sized upright speakers such as the ALTO II, ALTO III C or ALTO LINE. As subwoofer, the SUB W-20.39 would be a suitable choice.
No longer available.
Component parts list for 1 box
Tweeter
G 25 ND 8 Ohm
1 pc.
Woofer
W 100 SC 4 Ohm
2 pcs.
Crossover
Crossover CT CENTER 100
Terminal
1 pc.
Damping material
1/2 bag
Countersunk screws
3.5 x 25 mm
16 pcs.
Cable
2 x 1.5 mm2
1 m
Technical Data
Rated power
60 W
Maximum power
100 W
Nominal impedance Z
8 Ohm
Übertragungsbereich (-10 dB)
80 - 30000 Hz
Mittlerer Schalldruckpegel
87 dB (1 W/1 m)
Trennfrequenz
2000 Hz
Gehäuseprinzip
geschlossen / closed
Net volume
8 l
Außenmaß Höhe
210 mm
Außenmaß Breite
320 mm
Außenmaß Tiefe
195 mm
Frequency- and impedance response
