EFFECT 130
The EFFECT 130 is a Dolby® Surround effect speaker and can easily be used in conjunction with a CENTER 130 system. Thanks to the magnetically shielded SC 13 8 ohm driver, the system will be able to achieve the sound volumes required for clear reproduction of Dolby® Surround effects even in larger rooms. When Dolby® Surround signals are encoded, the upper frequency range is topped off at 7000 Hz, which is why the SC 13 8 ohm speaker, which remains linear up to around 10 kHz, is ideally suited to this application. In order to achieve spatial surround effects irrespective of the seating position, the SC 13 8 ohm has been designed to radiate the sound upwards.
The EFFECT 130 speakers can be located either freely around the room or mounted on the wall, where this should be behind or to the side of the seating position.
| Rated power | 80 W |
| Maximum power | 120 W |
| Nominal impedance Z | 8 Ohm |
| Übertragungsbereich (-10 dB) | 70–10000 Hz |
| Mittlerer Schalldruckpegel | 88 dB (1 W/1 m) |
| Gehäuseprinzip | geschlossen/ closed |
| Net volume | 4 l |
| Außenmaß Höhe | 250 mm |
| Außenmaß Breite | 160 mm |
| Außenmaß Tiefe | 160 mm |
