Do you have any questions?
Vox 300
The VOX 300 extends the high-end VOX series upwards. While the mid-to-high-range is the same as in the VOX 252, the TIW 360 8 OHM has been chosen as the woofer for this model. As a result, while the excellent characteristics experienced in the mid-to-high range remain the same, the level accuracy and dynamics in the bass department have been increased and the lower limiting frequency reduced to a remarkable 23 Hz. The VOX 300 can, therefore, be seen as the VOX variant for high-volume aficionados who like to hear concerts at close to the original sound levels in large rooms.
Technical Data
Component parts list
Additional Content
Rated power 300 W
Maximum power 600 W
Nominal impedance Z 4 Ohm
Übertragungsbereich (-10 dB) 23 - 25000 Hz
Net volume 100 l + 4 l
Außenmaß Höhe 1225 mm
Außenmaß Breite 260 mm
Außenmaß Tiefe 455 mm
Component parts list for 1 box
Tweeter:
KE 25 SC 8 Ohm
1 piece
Midrange driver:
AL 130 8 Ohm
2 pieces
Woofer:
TIW 360 8 Ohm
1 piece
Terminal:
BT 95/75
1 piece
Damping material:
7,5 bags
Crossover:
see diagram
Special wood screws:
5 x 30 mm
8 pieces
Wood screws: :
3,5 x 19 mm
12 pieces
Countersunk screws:
3,5 x 25 mm
4 pieces
Material for speaker covers:
width 50 cm
0,5 m
Cable:
2 x 2,5 mm2
3 m
2 x 1,5 mm2
2 m
Frequency- and impedance response
Contact us
