CT DIPOL 100
This dipole speaker makes use of two W 100 S 4 Ohm and two G 25 ND 8 Ohm textile dome units. The idea of dipoles is to create a diffused sound field from the effect channels. For this reason the tweeters at the front and rear are cross-connected. The all-pass circuitry in the deep-bass department ensures that, at frequencies above 200 Hz, the woofers are also cross-connected, and below that level they work in synch. This prevents the bass completely cancelling itself out. The two dipoles should be positioned at both sides of the listening position and just above ear-height or mounted on the wall at that height.
Apart from the CineTOP 100 combination consisting of 2x CT MAIN 100, 1x CT CENTER 100, 2x CT DIPOL 100 and the active subwoofer, it is also possible to combine the Centre and Dipole speakers with small or medium-sized upright speakers such as the ALTO II, ALTO III C or ALTO LINE. As subwoofer, the SUB W-20.39 would be a suitable choice.
| Rated power | 60 W |
| Maximum power | 100 W |
| Nominal impedance Z | 8 Ohm |
| Übertragungsbereich (-10 dB) | 80 - 30000 Hz |
| Mittlerer Schalldruckpegel | 85 dB (1 W/1 m) |
| Trennfrequenz | 2000 Hz |
| Gehäuseprinzip | geschlossen / closed |
| Net volume | 4 l + 4 l |
| Außenmaß Höhe | 260 mm |
| Außenmaß Breite | 400 mm |
| Außenmaß Tiefe | 173 mm |
Component parts list for 1 box
The kit includes all necessary components (see list below). Cabinet parts are not included.
